Page 6 of 6 FirstFirst ... 456
Results 101 to 107 of 107
Thread: NASCAR Bans Hutchens Device
Hybrid View
    Sep 2002
    Orlando, FL, USA
    2,322
    Originally posted by Wayne:
    Retrofit? You have a design that makes a single release point?? Both pins are pulled at the same time??
    Wayne
    Wayne,
    No. Technically that would not satisfy the single release requirement; you would have two release points.
    I'm referring to a change in the Isaac belt connector. Rather than capturing the belt with the mechanism, the belt slips into a "C" shaped component. You could either disconnect at the helmet as you do now, or drag it out the window, looking like a human TV antenna.
    BTW, this would not affect the performance of the Isaac system in controlling tension loads, but the increased friction at the belt connector would slightly increase early compression loads. We crashed a similar design at Wayne State so we know it's very safe.
    Kirk,
    You seem satisfied with your beta-tested, Enduro Spec model. What length would you recommend for the lanyard? We can have them made up in time for the new season.
    Gregg Baker, P.E.
    Isaac, LLC
    http://www.isaacdirect.com
    [This message has been edited by gsbaker (edited January 15, 2005).]
    Jan 2002
    Washington
    284
    Originally posted by gsbaker:
    Wayne,
    Ok, thanks. I'm purchasing new belts this year as well. Any special considerations I need to know about with regards to my existing issac, or the possible retrofit issac?
    Wayne
    Sep 2002
    Orlando, FL, USA
    2,322
    Wayne,
    There are no additional considerations. Just follow the instructions that came with your Isaac for checking the installation.
    Gregg Baker, P.E.
    Isaac, LLC
    Dec 2001
    LOS ANGELES CA AMERICA
    370
    Hey guys (and Gregg) Still looking around at H&N devices and checked out the LFT R3. I was just wondering what opinions anyone had on that system? Has anyone got one?
    I'm going to borrow a HANS for this weekend at Fontana.
    John Norris
    ITS E36 BMW
    Oct 2001
    Oregon City OR.
    1,550
    John, can you provide a little feedback on the Hans once you have tried it.
    Joe
    Sep 2002
    Orlando, FL, USA
    2,322
    John,
    See if you can borrow an Isaac system also. A large portion of our SoCal customer base is comprised of SCCA members, so you should be able to find an Isaac easily.
    The numbers on the R3 are pretty good. (Look for neck tension values. The rest is salesman speak.)
    The R3 comes in different sizes/shapes to accommodate different seat angles. This may or may not be an issue for you, depending on the cars you drive. Same with a HANS device.
    Whatever you try, make sure you can get out the window.
    Gregg Baker, P.E.
    Isaac, LLC
    [Edit: "Spelling is good" Founder of Faber College]
    [This message has been edited by gsbaker (edited February 03, 2005).]
    Nov 2001
    west palm beach, florida, usa
    475
    I can't get out of the window in my Miata regardless.
    Atleast not without hurting myself!
