Results 1 to 10 of 10
Thread: Volvo Oddball
    Jul 2003
    Portland, Oregon USA
    121
    Default Volvo Oddball
    Finished my first Novice race last weekend in a new car I just built. I believe it is the only Volvo 740 turbo in ITE anywherein the US. So far I am turning laps within 3 seconds of the winning ITE times at PIR. I can't imagine the car will not be competetive by next year. Some pics can be found here, with more to come.
    http://y3k.shacknet.nu:31338/gallery/view_...mName=NERD_Soup
    Peter Linssen
    ITE Volvo 740 Turbo
    ITB Opel Manta
    www.mvpvolvo.com
    Oregon Region
    Jul 2003
    121
    Now that's an oddball!, nobody even cares
    Peter Linssen
    ITE Volvo 740 Turbo
    ITB Opel Manta
    www.mvpvolvo.com
    Oregon Region
    Jul 2004
    Raleigh NC
    3,682
    Actually, I think it is pretty cool but my post didn't show up from two days ago.
    I asked a really newbie question - ITE what is it? (I'm not looking in the rule book, so no flames!) The Manta sounds cool too, got any pics? BTW, the link above seems to be broken which might be why nobody posted. I saw it two days ago, but tried again to no avail.
    Jul 2003
    121
    Thank's man I was feeling lonely. The gallery for NERDS racing seems to be offline for some reason. ITE is a regional class for overmodified cars. Here are the rules for my region.
    2004ITErules.doc
    SCCA – Oregon Region
    2004 ITE Rules
    Class Purpose and Intent:
    The intent of this class is to allow automobiles which have been
    modified and exceed or otherwise do not conform to IT class preparation
    rules (ITCS 17.1.4.D.1-10), or which are not listed in the ITCS a place
    to compete. ITE also provides a second-entry class to maximize track
    time. Entrants shall not be guaranteed the competitiveness of any car.
    Automobiles:
    1. All ITE cars shall meet or exceed all current GCR safety
    standards for IT competition (GCR ITCS:17.1.4.D.10 Safety). Fuel
    cells, fire systems and weld-in roll cages with NASCAR-style door
    bars are allowed and encouraged.
    2. All ITE cars shall run on D.O.T. approved tires.
    3. Any SCCA approved fuel is allowed in ITE. Diesel fuel is allowed
    in ITE in production engines designed for diesel fuel. Propane
    and Nitrous Oxide are prohibited.
    4. Any GCR recognized Touring, Improved Touring, Spec Miata or
    Showroom Stock legal car may compete under the rules specified
    for its class. Any modification beyond the specific rules for
    specified class shall require the vehicle to comply with the ITE
    rules.
    5. World Challenge, Firehawk cars are allowed in ITE and MUST
    conform to their respective rules set. Other Touring type cars
    from other series may be considered upon application to the
    Oregon Region Competition Committee. Competitors entering these
    cars in ITE shall be required to have in their possession a copy
    of the respective series rulebook for the specific make, model
    and year of the automobile entered. All ITE cars shall run on
    D.O.T. tires regardless of their respective series rules set.
    Any modification beyond the specific rules for the specified
    series shall require the vehicle to comply with the ITE rules. If
    a WC, Firehawk or other allowed Touring type car deviates from
    its respective spec rules in any way, it is no longer eligible
    under this rule (#5) and must comply fully with the ITE rules.
    6. SCCA GT and Production class race cars on D.O.T. tires are
    prohibited. Any car with GT or Production modifications, not
    otherwise allowed in the GCR-ITCS section or specified in the ITE
    rules, make a car ineligible for ITE classification. Tube-frame
    race cars are not eligible for ITE.
    7. All cars shall display the class designation ITE.
    Engine:
    Engine modifications are limited to the ITCS preparation rules (ITCS
    17.1.4.D.1-3) except for the following:
    1. Cars may use an alternate engine block. The engine block must be
    from the same manufacturer as the chassis. The engine must remain
    in the original location utilizing the factory engine mount
    locations. The engine block type (example: V8) must remain the
    same as originally delivered and/or offered for sale from the
    manufacturer.
    2. Induction systems and intake manifolds are free. Turbocharged and
    supercharged cars shall be allowed in ITE.
    3. Any flywheel and clutch combination may be used.
    4. Fuel and ignition engine management systems are free.
    2004ITErules.doc
    5. Crankshaft, camshaft(s), valve-train components, piston & rod
    combinations and engine & accessory pulleys are free. Cylinder
    heads, cylinder head porting, combustion chamber size and
    compression ratio are free. Aftermarket cylinder heads are
    allowed.
    Transmission / Final Drive:
    Transmission / Final Drive modifications are limited to the ITCS
    preparation rules (ITCS 17.1.4.D.4) except for the following:
    1. Any final drive ratio and gear ratio is permitted provided it
    fits the stock differential/transmission/transaxle housing
    without modification to the housing.
    2. Any limited-slip or locked differential is permitted.
    3. Factory manufactured all-wheel drive cars are eligible for ITE if
    they otherwise comply with the rules herein.
    4. Automatic transmissions are allowed. Transmission must be from
    Chassis:
    Chassis modifications are limited to the ITCS preparation rules (ITCS
    17.1.4.D.5) except for the following:
    1. Ride height is free.
    2. Springs/struts/shock absorbers / control arms are free.
    Aftermarket suspension components are allowed.
    3. Reinforcement of suspension attachment points is allowed.
    Brakes:
    Brake modifications are limited to the ITCS preparation rules (ITCS
    17.1.4.D.6) except for the following:
    1. Brake rotor and caliper upgrades are free.
    2. Factory anti-lock brake systems (ABS) are allowed.
    Wheels / Tires:
    Wheel and Tire modifications are limited to the ITCS preparation rules
    (ITCS 17.1.4.D.7) except for the following:
    1. All ITE cars shall run on D.O.T. approved tires.
    2. Wheel and tire size are free, within the limitation that the
    wheel/tire combination must fit completely within the front and
    rear fender well opening.
    Body / Structure:
    Body / Structure modifications are limited to the ITCS preparation
    rules (17.1.4.D.8) except for the following:
    1. Fender modifications are allowed for the purpose of tire
    clearance. Alternate fenders and doors are prohibited.
    2. Spoilers and wings are free.
    3. Bumper covers are free.
    4. Lexan glass is permitted for all window areas.
    5. Alternate hood and rear deck lid are allowed.
    6. Headlights and hardware may be removed. All wiring harnesses not
    required for the safe operation of the vehicle may be removed.
    Battery may be relocated within the body.
    7. Doors: left and right; must be able to be opened from the
    outside, Glass and attaching hardware may be removed. Cars with
    factory fiberglass or aluminum doors shall be required to utilize
    NASCAR style door bars.
    2004ITErules.doc
    Driver / Passenger Compartment:
    Driver / Passenger Compartment modifications are limited to the ITCS
    preparation rules (ITCS 17.1.4.D.9) except for the following:
    1. Interior trim pieces may be altered or removed.
    Fuel Testing:
    For this regional only class, that is not referenced in the GCR,
    cars shall meet fuel specifications as defined in GCR 17.4.1 for
    SS, T and IT classifications. Diesel powered ITE cars are exempt
    from fuel testing requirements.
    Where not specifically stated above, the GCR and/or IT specifications
    shall apply.
    Peter Linssen
    ITE Volvo 740 Turbo
    ITB Opel Manta
    www.mvpvolvo.com
    Oregon Region
    8,607
    IT "Everything" varies a lot from region to region and isn't even an option in some places. Some rules require that the car be logbooked from another series, past or present (e.g., WC Tourin or GT). Others allow all kinds of stuff but not forced induction. It's pretty much catch-as-catch-can.
    Apr 2002
    san jose ca usa
    22
    Hi Peter,
    Someone cares....
    Are you thinking about bringing the car to Thunderhill ever? I am racing a friends ITB 142 down here and have a 240 ITE project that I have been working on.
    Email me.
    Mike Saccone
    [email protected]
    Apr 2002
    san jose ca usa
    22
    Hi Peter,
    Someone cares....
    Email me.
    Mike Saccone
    [email protected]
    I care so much I went it twice
    [This message has been edited by sfrvolvo (edited September 15, 2004).]
    Jul 2003
    121
    OK, the nerds gallery is back up so the pictures are viewable.
    Hi Mike, I was trying to find your e-mail a few weeks ago. I do plan to make it to Thunderhill next season. I have too much on my plate to do any more races this year. Finish your 240, and we can race together next season.
    Peter Linssen
    ITE Volvo 740 Turbo
    ITB Opel Manta
    www.mvpvolvo.com
    Oregon Region
    May 2007
    1
    that car is a monster!
    Jul 2006
    48
    i care , but the damm link is broken
    95 integra IT2
    89 volvo 740 turbo
    www.ssccracing.org
