Results 1 to 5 of 5
Thread: where to get coil overs
    Feb 2004
    shirley ma usa
    30
    Default where to get coil overs
    i looking for some coil overs what kind should i go with???
    zracer22 Guest
    Ground Control
    Apr 2002
    Houston, TX USA
    2,555
    Call Jason at Paragon Products. Tell him Geo from Rennlist sent you.
    The folks at Paragon are fantastic. Excellent customer service, excellent prices, and excellent knowledge. Jason can give you all the information you need to select a good set of Konis. They carry the Ground Control coilover sleeves for the front. Coilovers for the rear are not legal of course. Jason can get you set up with rear torsion bars including custom ones if necessary (I just ordered some 32mm hollow bars).
    George Roffe
    Houston, TX
    http://www.nissport.com
    Maryland Heights, MO USA
    461
    Ground Control
    Lesley Albin
    Over The Limit Racing
    Blazen Golden Retrievers
    Royal Oak, MI, USA
    1,599
    Paragon.
    :b
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITA/GTS1
    www.vaughanscott.com
