Results 1 to 6 of 6
Thread: Relocation or Remounting Ignition componets
Hybrid View
    Apr 2005
    Port5land,OR
    1
    Default Relocation or Remounting Ignition componets
    If the stock location is not sutible for the coil that your using, can you remount the ignition coil somewhere else? For example inside the passenger compartment.
    Oct 2002
    Concord, NH 03301
    700
    I wouldn't see why not, you can use "any" coil.
    I'll be curious what others say since I have a car that the coil got moved (slightly) since it is a different shape than stock.
    Wauwatosa, WI, USA
    2,658
    ***I'll be curious what others say***
    ITCS 17.1.4.d.1.E. Any ignition system which utilizes the original distributor for spark & distribution is permitted.
    Have Fun
    Mar 2002
    Black Rock, Ct
    9,594
    How does the wiring harness rule figure in to this?? The coil is part of the stock harness, right??
    In other words, is having the coil "free" make anything that it connects to free?
    An academic question, really...
    ITA 57 RX-7
    [email protected]
    Wauwatosa, WI, USA
    2,658
    Are the coils part of the legal "Any ignition system"?
    Have FUN
    Nov 2001
    west palm beach, florida, usa
    475
    Well, it doesn't say you can remove the old system. And it doesn't say where you have to put it.
    Most people have hooked the ignition up where it is suitable to them. When I went from a VW coil to a Accel coil, the new coil was square. I located it somehwere else.
    It seems implied in the rules that you can remove the unused (replaced) stock ignition parts. It also seems implied that since our are replacing the parts, they wont be stock, and won't be the same size or fit in the same location.
    Put them where you want them.
    [This message has been edited by apr67 (edited April 27, 2005).]
