Results 1 to 11 of 11
Thread: Where to drill holes in cage for inspection?
    Dec 2003
    Charlotte, NC and CT, USA
    85
    Default Where to drill holes in cage for inspection?
    Wondering where I should drill the required holes for tech inspection in the rollcage. Where do most people drill them? Thanks in advance.
    Sep 2001
    alexandria, va
    851
    i bring a cordless drill to tech with the right sized bit and drill where the tech guy wants a hole. takes the guess work out of it.
    Jan 2004
    Pepperell, MA
    239
    Once upon a time, it was not totally unheard of for a car builder to sleave the rollbar where the inspection hole was drilled.
    That started the practice of using a length of welding wire to see if there were any "lumps" on the inside surface of the tube, as well as the inspector simply picking a location and having the hole placed there.
    More than one driver was very, very upset when told to drill a second inspection hole, and in two cases I remember, the drivers simply loaded their cars on their trailers and went home.
    Letting the tech guy pick the spot is easy.
    Sep 2001
    hampden,ma.usa
    3,083
    I would drill 3 @3/16". One in the main hoop, one in the front upright and one in a horizontal bar in the door opening. Do not drill where tube is bent and make it where there is room to measure the tube. Mark the area near the holes with paint or colored stickon dots. That said bringing a drill with you is good insurance.
    dick
    [This message has been edited by dickita15 (edited April 06, 2005).]
    Oct 2004
    Asheville, NC US
    1,626
    Remember that you must drill a hole in all REQUIRED tubes for inspection. It is easier to inspect if the holes in the main hoop, diagonal, and cross bar at door level all have holes near each other and the front tubes should be drilled about 6" off the mount plates. Good practice to drill holes at least 6" from any joints.
    8,607
    Eggs-ackly.
    Jun 2001
    Milwaukee, WI
    1,193
    To avoid drilling excess holes, take the drill with you to Tech. When I built my cage and we discussed it here, there were widely varying opinions and I was expecting to need to drill holes in all required tubes. Nope! Just one hole in the main tube is all the Tech Inspector wanted. He did pick the spot, however.
    To summarize: Take drill and bits with you to tech. If your tech is waived for an event, have the drill and bits ready for that, too, in case the tech inspector wants to look someplace else.
    Bill
    Planet 6 Racing
    Buffalo, New York
    2,942
    Take "pilot" drill bits with you. Makes starting the hole (where directed by the Tech Inspector)much less of a chore.
    Cheers
    Apr 2005
    Folsom, CA
    39
    I just had my new cage inspected, and the inspector wanted six holes drilled. I put them all on the passenger side in easy access places. He was able to measure all except the rear support brace while outside the car. He appreciated that. The six holes he wanted are as follows:
    1.) Main hoop upright
    2.) Rear support brace
    3.) Horizontal bar inside main hoop
    4.) Diagonal bar inside main hoop
    5.) Forward brace upright
    6.) Side impact brace
    Also, the logic of doing the passenger side is that if you are going to cheat with thin material on one side of the car, it probably won't be the drivers side where you're sitting.
    Curt Cearlock
    Apr 2003
    Charlotte, NC
    78
    It would be if you wanted to better balance the car's corner weights.
    Apr 2005
    Folsom, CA
    39
    Yikes! I suppose some would do that.
