Page 1 of 4 123 ... LastLast
Results 1 to 20 of 66
Thread: ECU mods
    Ottawa, Ontario, Canada
    665
    Default ECU mods
    If I start with a car that has an mass air flow sensor (MAF) signalling the stock ECU, but the modded ECU only accepts a manifold absolute pressure (MAP) input (all of the less expensive ones work this way), 1) am I allowed to add a MAP sensor to the intake manifold (assuming I can get the signal to the modded ECU through the stock ECU electrical connector), and 2) can I remove or disable the unused stock MAF sensor?
    Apr 2002
    Houston, TX USA
    2,555
    No in both cases.
    George Roffe
    Houston, TX
    http://www.nissport.com
    Guest
    Pandora's ECU box, what a nightmare.
    Nov 2001
    Kensington, CT, USA
    1,013
    The rule is simple - you can mod it as long as those mods are done within the stock box. Any mods or aditional sensors outside of the box are clear no-no's.
    Renton, WA USA
    1,625
    I believe this includes adding additional wires to the box... In other words, I'm pretty sure it must utilize the stock, unaltered wiring harness/connector.
    Darin E. Jordan
    SCCA #273080, OR/NW Regions
    Renton, WA
    ITS '97 240SX
    Sep 2003
    23
    I have the MAP sensor inside the ecu box and a vacuum hose going to the ecu box.
    8,607
    Clever... What rule are you using to allow the additional vac line? I've never thought about this approach.
    Oct 2001
    Portland, Oregon, USA
    78
    Plus, disabling the MAF might fit under the "altering the value" of the sensor. In this case you are just altering it to zero.
    Britt
    Soon to be SSC Mazda MP3
    Vintage Cosworth Vega
    Sep 2003
    23
    Thanks, but unfortunately I don't even know for sure if this is going to fly when the car is tech inspected. I wonder if anyone has been able to replace their ECU with aftermarket equipment while completely satisfying the rules.
    Sep 2003
    23
    Oh, and for anyone who's interested I used a megasquirt EFI controller. Why? It was cheap and a fun project that kept me busy for months on end. I love projects and I learned a TON about EFI systems. At this point I've tuned it and only assume it's making extra HP, but being able to monitor exactly what's going on with my car is what makes it worth it. http://www.bgsoflex.com/megasquirt.html
    BTW Kirk, I've been talking to you on honda-tech/RR as Eric.
    Apr 2002
    Houston, TX USA
    2,555
    Tech inspectors are not going to look at your car for anything other than safety issues unless someone protests you.
    Your car will be illegal.
    17.1.4.D.1.a.6:
    "Fuel injected cars may alter or replace the engine management computer, or ECU, provided that all modifications are done within the original OEM ECU housing. Only the stock (unmodified) OEM ECU connection to the wiring harness may be used. The allowance to modify the ECU in no way permits the addition of wiring, sensors, or piggybacked computers outside of the OEM ECU housing. The stock (unmodified) wiring harness must be used. Adjustable fuel pressure regulators are permitted."
    Unless you were able to fit the stock MAP sensor in the ECU, I don't see how you can get around the fact you are not allowed to add sensors. Also, I don't see how you can get a vacuum line into the ECU housing w/o modifying it.
    I wish tech inspections looked for cheating.
    George Roffe
    Houston, TX
    Sep 2003
    23
    I still have all the original ECU parts so if I ever start doing any actual competition I can revert back to it. I don't know why, but I have a feeling no one is really going to care about my ecu unless my driving skills + car = unfair advantage. I have a ways to go before that happens...
    Nov 2001
    Kensington, CT, USA
    1,013
    <--- ducking and covering
    Mar 2002
    Black Rock, Ct
    9,594
    <---- biting my tongue ....
    ITA 57 RX-7
    [email protected]
  15. #15
    Apr 2002
    Bridgewater, MA USA
    1,300
    Once again supporting my theory that the illegal cars are in the mid-pack trying to keep up with the ultra-prepped, well driven cars. No offense intended, just an observation.
    AB
    Andy Bettencourt
    06 ITS RX-7
    FlatOut Motorsports
    New England Region #188967
  16. #16
    8,607
    I could be wrong but I don't think that Eric is actually racing in IT with this set-up...
  17. #17
    Feb 2002
    Dallas, Texas
    52
    Is it legal to replace a standard O2 sensor with a wide band O2 sensor?
  18. #18
    665
    Very interesting, I hadn't thought of putting the MAP sensor inside the box either. I know of several computer boxes (VW) that do have a vacuum connection to the intake (I think for ignition advance rather than fuel metering), so they already have a MAP-type sensor in the box I guess we could use that as the main sensor and just let the computer do whatever it wants with the extra MAF input. Now, do we have to use the stock injectors?
  19. #19
    Flagtown, NJ USA
    6,335
    AB
    Andy,
    I'd like to hear the explanation of that one.
    SCCA 279608
  20. #20
    Sep 2003
    23
    I am not doing any competition of any kind at this point. I'm still learning about racing and learning/working with my car; especially since it has been Winter. I probably won't do any competition this Summer, even.
    When I started building that ECU I realized I could more or less make it conform to the rules. So far I just have to deal with a vacuum hose that shouldn't be there. I've overcome a lot, though.
    Even if I cannot possibly find a way to make it work I will just have to switch back to the stock set up. I mostly built that ECU for the fun of it. It only cost about $200 to do and as far as I can tell performs like a $2000 set up.
    Pics of my ECU... I got this far! I passed the emissions test without a cat...
    http://b18c5.org/race/ecu/
    http://b18c5.org/race/ecu/10.jpg
    http://b18c5.org/race/ecu/passed.jpg
