Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Discrepancy in GCR concerning wheels for my car...
    Nov 2003
    Buffalo, NY
    127
    Default Discrepancy in GCR concerning wheels for my car...
    Here is the email I sent to the SCCA concerning my situation, I would much rather run the stock 14" wheel size because the tires are much cheaper, and the wheels are lighter.
    "I am in the process of building a 1995 Mitsubishi Eclipse RS into an ITA racecar, however I noticed a discrepency in the 2004 GCR concerning this car. In the ITCS section 7.a.1 (wheels and tires) it states "All other cars shall retain the wheel diameter fitted as original equipment for their make, model, and type." My car came with 14" wheels as original equipment, however in the list of cars under 1995-98 Mitsubishi Eclipse the only wheel size listed is 16", this seems to contradict the wheel and tire rule, which tire size am I allowed to use on this car?"
    Apr 2002
    Houston, TX USA
    2,555
    Did you include factory documentation with your e-mail? If not, you may want to follow up with a scan of factory documents (FSM, owner's manual) to support your request.
    George Roffe
    Houston, TX
    http://www.nissport.com
    Nov 2003
    Buffalo, NY
    127
    I have a picture of the doorjamb, and a scan from the factory service manual, think that will be enough?
    Apr 2002
    Houston, TX USA
    2,555
    I would highly recommend sending the scan from the FSM.
    George Roffe
    Houston, TX
    Jan 2003
    217
    Not to steal this thread, however, I run a ITB Mustang and if I can run the wheels that came stock can I run a 15x7. The magic book already says 15". What about 7" if they are even stock rims?
    8,607
    Diameter is spec'd by the ITCS book - width by the class. ITB is allowed 6" max width of wheel.
    Nov 2003
    Buffalo, NY
    127
    Thanks, I sent a follow up with it included.
    8,607
    Just anticipating potential hiccups, you'll need to make it clear from whatever you send that (a) you are working on a car that meets the dates and model of the spec line in question, and ( the documentation applies to all of those same years/models.
    It is pretty common for the cars listed in the ITCS to not include all of the eligible years that a model was produce, for the trim levels to be incorrectly or incompletely listed, or for specs to be incomplete. But you knew that already, right?
    Have fun!
    Kirk
    Nov 2003
    Buffalo, NY
    127
    I heard back from the SCCA today, they say the wheels size should be interpreted as the maximum size, so guess I can use 14, 15, or 16" wheels.
    "Michael,
    Take a look at page ITCS-37. If you look at the Mitsubishi's specs, it lists the wheel size as 16". The wheel size should be interpreted as a maximum wheel size.
    Regards,
    John"
    Nov 2001
    Kensington, CT, USA
    1,013
    WHAAAA???? Does that mean that we can all use smaller diam wheels?!? And all this time I thought....
    Nov 2001
    Kensington, CT, USA
    1,013
    Does that mean you could use 13"s?
    Can you use 15's because your spare is a 15?
    8,607
    No, no, no, no, no. That is wrong. I don't care what John thinks, it is just wrong.
    [This message has been edited by Knestis (edited February 11, 2004).]
    Nov 2001
    Kensington, CT, USA
    1,013
    I gotta get a hold of this "John" guy. Maybe he'll let me run a Turbo!
    Renton, WA USA
    1,625
    Originally posted by Knestis:
    No, no, no, no, no. That is wrong. I don't care John thinks, it is just wrong.
    I agree with Kirk... there is no basis for this interpretation that I've ever read... Otherwise, why list multiple sizes and not just the maximum...
    Darin E. Jordan
    SCCA #273080, OR/NW Regions
    Renton, WA
    ITS '97 240SX
  15. #15
    Apr 2002
    Houston, TX USA
    2,555
    Yeah, Darin is right.
    Look, the last thing you want to do is to invest in some wheels and find out they are worthless for your purpose.
    Keep in mind there has been a relatively recent change in the technical staff at SCCA HQ. There are a lot of rules to be up on. The interpretation you received is wrong.
    George Roffe
    Houston, TX
  16. #16
    Feb 2003
    Grove City, OH, USA
    1,449
    Was there a correction issued to amend the 2003 GCR? The copy that I have lists on page ITCS-33 Plymouth Laser/Eagle Talon/Mitsubishi Eclipse 2.0L (no specific years) Wheel Dia. (inch) 13. Another reason why the rules should be available in updated form online!
  17. #17
    Nov 2003
    Buffalo, NY
    127
    I don't know, I have the 2004 book and didn't notice what you see, it sounds like the 89-94 model you are talking about, mine is a '95
  18. #18
    Nov 2003
    Buffalo, NY
    127
    Yeah, good point...His name is John Bauer BTW, he copied Jeremy Thoennes on the message as well.
  19. #19
    8,607
    Email him back (and cc Jeremy) asking for the court of appeals case information that establishes this change in ruling. The IT rules are based on the SS rules that specifically required (and continue to require) OE wheels.
    This kind of thing is really irritating and should be added to the list of ways that rules creep happen.
  20. #20
    Nov 2003
    Buffalo, NY
    127
    I emailed him back, his response was...
    "Michael,
    This is my observation from countless hours of reading the GCR. Anytime you can go to the dealer and pay extra for an upgraded package that includes larger wheels, it is ok to put the larger diameter wheels on the car without the upgraded package. I hope that made sense. If it didn't email me back!"
    So here's what I'm going to do...Run 14's, if anyone whines, I'll have my service manual, the rulebook, and printed copies of the emails.
