Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Sleaving a block
  1. #21
    Oct 2001
    Oregon City OR.
    1,550
    Guys I would be happy to have anyone of you protest my sleaved block. This is a standard machining practice. Simple as that there is no performance advantage. Only an over anal reading of the rules could keep you from reading it any other way. Engines may be bored.040 over standard bore size. good enough make sure you meet this spec.
  2. #22
    Apr 2002
    Houston, TX USA
    2,555
    Originally posted by 122 Vega:
    There is no curent process that allows the zinc/iron plating on the pistons like what was stock.
    You sure about that? There are Porsches, BMWs, and Mercedes that run the same sort of thing.
    The later factory service manuals offered sleeving with iron sleeves as an appropriate procedure so the dealers would not have to maintain expensive lapping kits for a dying breed.
    I guess it would be legal then.
    George Roffe
    Houston, TX
    http://www.nissport.com
  3. #23
    I loved my Vega even though when you pulled into a gas station the routine was to fill the oil and check the gas.
  4. #24
    Dec 2002
    Central Texas
    616
    And don't forget you had to fill the radiator back up too. I had as much steam out the tail pipe as a did oil smoke. All in all The Vega was one of my favorite cars.
  5. #25
    Mine never passed coolant although it popped a rad once.
    I put over 145,000 miles on that sucker in 8 years and sold it for $90.00
    The body rust was tragic.
    Cheers.
  6. #26
    Oct 2001
    Portland, Oregon, USA
    78
    Ohh...I get it, you don't get protested if your car breaks down after three laps...
    I'm immune to protest!
    Britt
    Soon to be SSC Mazda MP3
    Vintage Cosworth Vega
  7. #27
    Apr 2001
    West Palm Beach
    138
    There were plenty of sleeved vegas out there as it was the dealer performed repair and factory authorized.
