I have a 95 Chrysler Sebring LXI that I want to turn into a Improved Touring Car.
Im located in Auburn, Mi does anybody know who installs roll cages in Michigan?
Hum, I'm surprised no one has chimmed in on this one yet... So I get to be the FIRST!
3 comments for you. Please take these as helpful comments only, we want you to join us on the track, these may help clear things up and make it easier for you.
1 - search the forums, this topic comes up a bit
2 - Buy a GCR from SCCA (I don't remember seeing the Sebring listed anywhere in IT, I also don't remember Sebrings being available with a munual trans.... but I could be wrong about both of those)
3 - BUY a car already built. Much easier, much quicker and ultimately cost less.
Ben
Hold off on the cage there bud. First item of business is to get the car classified in IT, because as of right now, it's not there.Originally posted by kaioken:
That being said, some places might let you run in ITE, where you'd probably, um, not be competitive... Also, you might work in a local IT class if you're going to run specifically at Waterford Hills or somewhere, but you'd have to check out their rules to see if you're eligible...
Better start writing letters to the CRB if you want it in one of the main IT classes...
Matt Green
The Eclipse and Avenger/Sebring are all dsm.
Engines and Drivetrain can be swaped.
1995-1999 Mitsubishi Eclipse 16V non-turbo 1950
1995-1999 Mitsubishi Eclipse 16V turbo AWD 2910 add 50 pounds for AWD
Sorry about posting this in the wrong spot.
That's irrelevant. The body type is not classified. The Avenger is also not classified. As a side note, the stratus is, but again, different body. You cannot run the Sebring in ITA unless it gets classified (which I'm pretty sure it hasn't in the last two months).Originally posted by kaioken:
Matt Green
Oh, and where the heck do you see a listing for the AWD turbo Eclipse in IT? Or am I missing something here?
Matt Green
I have no idea where you are getting your numbers from, the only DSM of that era that is classified is the 95-98 Eclipse FWD 2.0 non turbo and the weight is 2650lbs.
I contacted John Bauer the Technical Assistant for Club Racing and he sent me the Vehicle Technical Specification (VTS) sheets.
I will try and keep you guys posted.
This is interesting....
Someone from the National Office sending specifications for cars that aren't classified. Not to mention that the IT rules specifically prohibit both forced induction and all wheel drive.
Bob Hudson
Atlanta Region SIT
Bob Hudson
Atlanta Region SIT
Land the black helicopter, Bob. Those are the forms used to apply for classification. Topeka prolly has no idea what a Chrysler Sebring is.
The Chrysler Sebring and Dodge Avenger are not
forced induction or all wheel drive. And far as where I got the awd information was from the www.ustcc.com site. Sorry about that. Not to be related to IT.
If and when you are ready to build your car you should contact the company that I work for. Skytek Engineering has a history with Chrysler race cars. We have built many winning Neons includng the two factory SRT-4's that ran at last years Run-offs. We would be more than happy to help you out and we are in Rochester Hills Mi. Contact Pete Taylor at 248 856-2000.
Helicopters landed and shut off....
Right, we all know that, we also all know that the Sebring and Avenger are not classified in IT yet, so as of now you are SOL. If it does become classed (You can try to make that happen by contacting the SCCA) you will not be able to swap in a turbo engine or any other engine for that matter.
Yes, I know that I cant swap the motor for one with a Turbo now..
OK, so...we all know it's not in an IT class, and if it gets put in one it will have to run in original engine configuration...
So...when the request gets approved, which class will it fit into??
(And, the crux of the isssue is, really, what class does the applicant WANT the car to be in, knowing what mods are allowable, and the potential perfomance HE thinks is reasonable??)
Final point is that I am not sure this car (and I admit to not having a good handle on this model) will fit in the faster classes, but might be perceived as too large fort he slower classes.
Maybe ITB?
ITA 57 RX-7
Nah, probably ITA.Originally posted by lateapex911:
Maybe ITB?
Car was about 2800-2900lbs, which can be brought down to 2700 or so with IT legal gutting probably. Uses a 2.0 DOHC engine that would make about 160hp (or slightly more) in IT trim. Basically, Neon power level but toting around 100 more lbs. or so.
The 98 vintage Eclipse is already in ITA with the same engine at 2700 lbs.
Just thinking out loud, but I'd like to know from the ITAC guys if I'm thinking along the correct lines if possible...
Matt Green
Jake,Originally posted by lateapex911:
W/ the New Oinker, I mean New Beetle in ITC, I don't think the weight issue is much of an issue.
SCCA 279608
True...I thought the car was larger. If it can get to 2700, A might be a consideration. But I think of the rentals I have had and I just don't see it in ANY class ! But mods can do a lot....
ITA 57 RX-7
