Results 1 to 8 of 8
Thread: Oil Pans
    Nov 2004
    somewhere between here and there
    46
    Default Oil Pans
    I have a neon oil pan question. The car I have has a steel oil pan. I was in the junkyard the othe day and noticed a sohc neon that had a cast aluminum pan. Dose anyone know anything about it? Is it better than the steel pan? It looks bigger than the steel pan. Thanks Dave
    Purcellville, VA USA
    902
    DOHC and later SOHC engines had aluminum pans. Potentialy adds rigidity to the assembly.
    Flagtown, NJ USA
    6,335
    May be lighter, and more rigid, but probably less 'compliant' in the event of an off.
    SCCA 279608
    Aug 2003
    Delaware, OH
    222
    Heat disipation is better too with the aluminum , but there was a car at the 25 Hour (Team Orange) that lost a motor because of an off that cracked the cast pan......
    Jeremy Lucas
    Team Honda Research
    Kumho - Cobalt - Comptech
    buffalo,n.y. u.s.a.
    357
    You may want to research the pan to see if it has any compartments that differ from the steel one.
    Nov 2004
    Boyertown, PA- USA
    454
    Nope.
    And yeah, they can be cracked more easily by, uh, debris... Yeah debris.
    Also, don't run the BIG filter (PH8A) on the Neon as it will be the lowest thing hanging down, and I'm told that hard curbing can possibly contact it if you get overzealous...
    Matt Green
    Feb 2004
    st. louis mo.
    433
    The cast aluminum pan was introduced because of NVH (noise vibration harshness?)it also holds 1/2 qt. less....moroso makes a nice 7qt. aluminum plate(not cast) pan (don't know the cost)as far as the filter goes remote is better...hope this helps
    Nov 2004
    46
    Thanks for the help guys. I guess I will stay with the steel pan until I save my pennies for the morroso pan. It runs about 350. And I will be relocating the filter too. Thanks again . Dave
