Results 1 to 5 of 5
Thread: Springs - Can anyone help?!?!?!?!?!
    Jul 2004
    Raleigh NC
    3,682
    Default Springs - Can anyone help?!?!?!?!?!
    I'm going crazy.
    I need some 3" ID, 7" length, 650lb springs for the front of my car.
    I order them from company XXXXX, where XXXXX is Pegasus, TrueChoice, etc. They say fine, we'll have them in a week. They call back and say they cannot get them. This has played out about 5 times now and I'm going crazy.
    Can anyone help me with a source for these springs, or something close?
    Thanks!!!!!
    Ron
    Ron
    http://www.gt40s.com
    Lotus Turbo Esprit
    Ford Lightning
    RF GT40 Replica
    Jensen-Healey: IT prep progressing!
    Feb 2004
    cfr
    391
    I've never used them for a race application, but you might try Coil Spring Specialties at 785-437-2025 or http://www.coilsprings.com
    Jim
    Wauwatosa, WI, USA
    2,658
    Ron, if the springs you require are for the Jensen-Healey maybe you need to talk with someone from a British car shop. Or try different manufactures of springs then ask the manufacture who sells them. Or go here & try. www.coloradoscca.org/prodcar/
    Have Fun
    Jan 2002
    Somewhere in Upstate New York
    1,033
    Check with the roundy-round shops - AFCO, Coleman Machine, Lefthander. They have all sorts of spring length/ID/rate stuff in their catalog.
    Edit - oops...forgot that Landrum Spring does coils, too - they did some really weird 'rate & width' leaf springs for me in the past - http://www.landrumspring.com/pages/coil.html
    Is the 3" ID a hard number ? Can't get by with a more standard 2 5/8" ? What about OD - can you go to the bigger OD springs (5" or bigger pig-tail or ground ends) to get the ID you need ?
    Length/rate should be easy, once you find the right ID/OD. If the sizes offered are too long, just buy a longer & lower rate spring, do the math and cut the damn things off.
    [This message has been edited by JohnRW (edited December 08, 2004).]
    Jul 2004
    Raleigh NC
    3,682
    Thanks for the help fellows, that first one, www.coilsprings.com, was really good. Told them the specs and had a good quote in 30 minutes - 1/2 the cost of anything else I'd even heard. R
