Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
Thread: Since we had so much fun with cam timing..how about Brakes
    raleigh, nc, usa
    5,252
    Default Since we had so much fun with cam timing..how about Brakes
    Here's a question. I'm having a b$%^h of a time keeping the tiny little pads, rotors and calipers on the front of my car cool. Ducting is free, right, as are modifications to the backing plate to allow air to reach the rotor, right?
    So, I can I put on one of those "tophat" things I saw in Carrol Shelby's book on cooling solid discs that is basically an extension of the backing plate? It's basically a modification to the backing plate that directs air to both sides of the rotor....fire away guys, tell me what you think.
    Jeff
    Apr 2002
    Houston, TX USA
    2,555
    I think that's legal and it's exactly what I'm going to do.
    "Backing plates and dirt shields may be ventilated or removed. Air ducts may be fitted to the brakes, provided they extend in a forward direction only and that no changes are made in the body/structure for their use."
    Of course in another part of the ITCS it specifically allows holes of certain dimensions to allow for brake duct hose.
    George Roffe
    Houston, TX
    http://www.nissport.com
    raleigh, nc, usa
    5,252
    Ok...one down, one to go.
    Next potential "solution" I have looked at is a fluid recirculator. It's basically a check valve in the brake line that allows fluid to flow out from the caliper when I use the brakes, to be replaced by other fluid in the line, using a line coming out of the bleeder nipple.
    I was real iffy on this one to start, but then I looked at the GCR. Brake lines are free, and I've seen all kinds of crazy spirals and other things in the lines on other people's cars, so would "brake lines free" mean I can put this check valve in so that I can get the hot fluid out of the caliper before it melts my seals -- as it has been doing on a regular basis?
    Feb 2004
    st. louis mo.
    433
    Is it brake fluid temp or rotor temp that is melting your seals?...the ducting should help with that....I'm wondering if blowers like sold at pe----- are legal??
    [This message has been edited by m glassburner (edited September 21, 2004).]
    raleigh, nc, usa
    5,252
    Not sure. I don't think the fluid is boiling, but I can see the seals smearing across the piston. So, not sure what is getting "too" hot although I suspect the fluid is way above the melting point of the rubber seals.
    I thought about the blowers but considered them definitely illegal -- nothing at all in the GCR about electric motors in your brake ducts. At least with the brake recirculator it is simply a check valve and additional brake pipes where brake lines are "free.' While I would like some that are more knowlegeable on these matters to weigh in, I think I at least have an argument here.
    But we will see.
    Apr 2002
    Houston, TX USA
    2,555
    I don't see how a check valve can be construed as brake lines.
    George Roffe
    Houston, TX
    Jan 2003
    Moline, IL
    59
    Wheel fans are legal.
    west palm beach, florida, usa
    475
    The seals should never touch the brake fluid, they are really 'dust boots'. (unless you mean the rubber brake pistion ring that some brakes have).
    I am sure that the seals are burned up from the brake heat.
    Alan
    Jul 2004
    Raleigh NC
    3,682
    Don't know, but I'll make them for you. And, I'll put some peltier devices on there for you too, with big heat sinks. But what do I know, I've got adjustable cam gears I'll use too, so look out.
    Flagtown, NJ USA
    6,335
    Have you used any of the temp-sensitive paint to see just how hot the components are getting?
    SCCA 279608
    Jul 2004
    Raleigh NC
    3,682
    Or stick a couple of thermocouples on there and we'll log the temp and figure out exactly what is going on. Might have to do that on a test day.
    raleigh, nc, usa
    5,252
    Alan, I don't use the dust boots, it is the rubber seal about 1/2 down the piston that is melting.
    Ron, we'll take a look at it. Really annoying this problem.
    George: just thinking out loud here, not really taking a position. How is the valve and additional lines any different from additional lines and a proportioning valve? Not sure that I see any real distinction.
    Wheel fans are legal??
    Oct 2001
    Rancho Cucamonga, CA, USA
    1,066
    Per GCR 17.32 they are legal. Not sure how that affects the wheel width rule though....I'll stay out of that one.
    Daryl DeArman
    Apr 2002
    Houston, TX USA
    2,555
    Proportioning valves are specified as legal.
    A check valve for recirculating brake fluid cannot be confused with a proportioning valve. I don't see any other way to slide the valve under the rules. It's not a line which is free. There is just no provision for it.
    George Roffe
    Houston, TX
    Black Rock, Ct
    9,594
    Jeff, I know where you're coming from...I've been there myself...but its a stretch at the very least. I gotta go with the guys here and say that adding check vlaves is beyod the scope of "brakelines are free".
    The one phrase that caught my eye is the "brake circuitry may be revised", but adding lines and check valves is way more than revising.
    And the proportioning valve sits in line..no added lines needed. The ITCS only allows pressure limiting P valves. (Which are limited in their use at the greater adjustment settings as they hinder the release of the brakes, making modulation difficult. (or so I read somewhere! )
    Nice idea though!
    ITA 57 RX-7
    [email protected]
    Feb 2004
    st. louis mo.
    433
    Wheel fans are just a different type of rim I thought ?? Designed to help move air ...
    475
    Wheel fans are sorta like hubcaps, and they extract air from the wheels.
    They are specifically disallowed in the GCR for some classes (SS, SRF) if I remember correctly.
    IT is not one of the restricted classes, again, as far as I can remember.
  18. #18
    Ottawa, Ontario, Canada
    665
    No opinion on whether or not checkvalves are permitted, but I think it should be possible to do fluid recirculation without any.
    Idea #1: use a feed line with a larger diameter orifice at the master than at the caliper, and/or a return line with larger diameter orifice at the caliper than at the master.
  19. #19
    Flagtown, NJ USA
    6,335
    George,
    How about if it's incorporated into the brake line? Brake lines are free, nothing says what you can or can't do w/ them.
    SCCA 279608
  20. #20
    raleigh, nc, usa
    5,252
    That was sort of my thinking, coupled with Jake's reference to the brake circuitry (aren't lines and valves and such what they are referring to here?) being subject to revision, that lead to me concluding it was legal.
    I might write Topeka on this. Sort of one of those things in the gray area that certainly moves IT farther away from stock cars with cages and suspension to true race cars........
