Results 1 to 8 of 8
Thread: IT Fuel Cell
    Sep 2004
    Winchester, VA
    10
    Default IT Fuel Cell
    I'm planning on installing a fuel cell in my e30 this winter. I've been looking around and found the ATL D cell (or "well cell as its nicknamed). Its shaped to drop into the spare tire hole in the trunk.
    Anyone out there have any experience with it?
    If so, how bout a surge tank, what kind of fuel pump system?
    Or, any other suggestions?
    D. Walter DeHaven
    ITS BMW e30
    Jul 2003
    Portland, Oregon USA
    121
    Yes, I installed a 12 gallon well cell in my Volvo ITE car. I used the "black box" that ATL cells as a baffled system inside the cell I use a low pressure feed pump (12psi)to feed the stock high pressure pump. You could also just use a high pressure high vollume pump in the surge tank. Installation is sweet with no problems on track at all. I do not have access to my pictures right now or I would post them.
    Peter Linssen
    ITE Volvo 740 Turbo
    ITB Opel Manta
    www.mvpvolvo.com
    Oregon Region
    Dec 2001
    raleigh, nc, usa
    5,252
    Same here, I have the ATL well cell. Fits nice, and doesn't move around at all. Weight is low, much lower than the stock tank location (although within the 12" rule). A little farther back and exposed, but so it goes.
    I run carbs and have a low pressure Holley blue, but have no problems with fuel cut out even without a surge tank. Also heard this weekend of a racer's trick: simply install another fuel filter in the line but leave the element out. There's enough fuel in the filter body to serve as a surge.
    Jeff
    Jul 2004
    Raleigh NC
    3,682
    Jeff[/B]
    If you've got the big canister filters. I know of one track GT40 that uses two of these things and it works well, the poor mans surge pot in a way. Although I suppose some heniously long sweeper could cause problems.
    Question - fuel cell located within 12" of the stock location. In my car the stock location is the trunk, that has a completely flat floor, and it is located about 15" behind the driver. Could I put a fuel cell underneth the trunk, effectively putting it outside the car? People are really going to laugh when they see where the stock JH fuel tank is, Jeff doesn't even think the tech inspector will believe it.
    Ron
    http://www.gt40s.com
    Lotus Turbo Esprit
    BMW E36 M3
    RF GT40 Replica
    Jensen-Healey: IT prep progressing!
    Sep 2001
    alexandria, va
    851
    trunk fuel cell in an e30 "may" be safer, but is definitely not in a good location. can't beat the stock location of the bottom of the car and in front of the rear axle.
    marshall
    ex-its e30 driver
    Dec 2001
    raleigh, nc, usa
    5,252
    Ron, yes, you can go under the trunk. The way this rule is interpreted in La-La IT Land is that if any part of the cell is within 12" of any part of where the stock fuel tank used to be, you are ok. So, conceivably, you could put it in a side car if you wanted.
    Apr 2001
    Belmont, CA USA
    1,098
    I did a Fuel Safe cell into the spare tire well of my Rabbit when I converted to Limited Prep G Production.
    Yes, you WILL need some kind of sump tank because the Fuel Injection needs position pressure all of the time.
    What I did was purchase an external tank from Summit Racing, P/N SUM-300101, and added 2 additional fittings to the top. I now run a Facet electric pump between it and the cell.
    So the connections are as follows: 1st one on top comes from the pump / cell. 2nd one on top is the return FI line from the motor, 3rd one on top returns to the cell. 1 on the bottom feeds the stock Bosch electric (stock) fuel pump.
    the only thing I need to do is mount it up a little higher, so off road excursions won't damage the bottom connection / line.
    Pictures of the cell, sump tank, etc:
    http://linerud.myvnc.com/racing/2002/
    Tim Linerud
    San Francisco Region SCCA
    #95 GP Wabbit
    Trussville, Alabama, USA
    1,087
    What Marshall said, DOUBLE!!!
    Chuck Baader
    #36 ITA E30 BMW
