Results 1 to 9 of 9
Thread: Front Tow Hooks
    Jun 2001
    Milwaukee, WI
    1,193
    Default Front Tow Hooks
    Well, with the impending rule change and since I have the nose off the car right now anyway, I figured it would be a good time to look at adding the front tow hook. But, my question is where best to add it?
    I don't have a factory front tow hook, so I can just extend that. I want to avoid the pitfalls of just tying into the bumper, as I'd like not to have safety remove my bumper for me.
    That said, about the strongest point that I can see would be where the subframe connects to the main frame near the radiator. The easiest route would be just to wrap some high-strength nylon webbing around this point and out through the bumper. Any thoughts?
    Bill
    Planet 6 Racing
    311
    I've been looking at my car as well, and am considering the same thing. However, use a piece of cable instead of nylon. It will be less likely to break if it hits a sharp edge and it won't be damaged by the elements as much (remember the seatbelts saga ).
    Jun 2001
    Milwaukee, WI
    1,193
    I was thinking about using chain, but that is just extra weight. The nylon should be nice and light...
    I will look at the wire rope/cable, though. That would work pretty well, I think.
    Bill
    Planet 6 Racing
    Jan 2004
    Camas, WA
    531
    How about this?
    http://www.turnermotorsport.com/html/detai...?PRODUCT_ID=TOW
    I just added one to the front of my rx7.
    Marcus
    Jan 2003
    Cumming, GA, USA
    425
    Just make sure you do a better job than Chrysler did with the factory ones on the Viper Competition Coupe. At this weekend's Petit le Mans, one of the Viper CC's stalled or something at the start, and the crash truck tried to tow it off the track surface. The car moved for maybe ten or twenty feet, then the tow "eye" came loose, just about the time the leaders got back to the front stretch. Screwups all around, but the tow "eye" pulling off was a major one.
    Doug "Lefty" Franklin
    NutDriver Racing
    Jun 2001
    Milwaukee, WI
    1,193
    That's exactly what I'm trying to avoid. The TMS strap, while similar in concept, relies on the bumper to pull the car out. However, on my car at least, the bumper was not designed to be pulled on, so I'll be wrapping the strap around the chassis.
    Bill
    Planet 6 Racing
    Jan 2004
    Maryland
    64
    I went the chain route first to the factory tow eye, but when I got 'on the rope' the chain had enough side to side movement that it messed up the valance pretty well. Since then I have put on an eye that is on a short piece of tubing welded to the frame.
    http://www.mindspring.com/~timelapseracing...g21-1%20(6).jpg
    http://www.mindspring.com/~timelapseracing...g21-1%20(2).JPG
    Jason.
    1989 ITA 240sx - #21 MARRS Series
    Apr 2001
    Belmont, CA USA
    1,098
    I went with something a little bit "beefier"
    http://linerud.myvnc.com/racing/2003/April...il-LS/April.jpg
    It's a 2" receiver 4x4 assembly, that is bolted to the factory 5 mph bumper "shock" housing.
    The tow truck would bend the frame before this lets go.
    I also have one in the rear.
    Kind of heavy, but so is the car and driver.
    Tim Linerud
    San Francisco Region SCCA
    #95 GP Wabbit
    Nov 2001
    New England
    267
    Bump drafting should be fun with toe hooks protruding from bumpers...
    Anthony R.
    ITA #86 NER
