Results 1 to 15 of 15
Thread: Toyo tire pressures?
    Aug 2002
    Austin, TX
    75
    Default Toyo tire pressures?
    Does anyone have experience with both Toyo and Hoosier (a3s03) tires? I normally run Hoosiers and try to get them around 40 to 42 psi hot. This past weekend I tried Toyo for the first time (with a NASA event) and by seat of the pants, they also seemed to like low 40's hot. Just wanted to see what folks think. I normally don't have someone at the track that can take temp profiles or pressures in the pits, so I am guessing a bit.
    My car is a 2500# 240Z in ITS.
    Jeff
    Feb 2003
    Scottsdale AZ
    322
    The Toyo web site www.toyo.com/tires/tire_lines/high_perf/ra1.html
    recommends high 30's to low 40's. I try to come off the track at around 39 or 40, which usually means starting with 32 front and 34 rear on my Spec RX7
    [This message has been edited by pgipson (edited March 13, 2004).]
    Oct 2002
    Wandering the USA
    1,341
    A3S03 for ITS?
    Marty Doane
    ITS RX7 #13
    CenDiv WMR
    Apr 2003
    Connecticut
    130
    I talked to Toyo, used my pyrometer, and used my butt, and it really looks to me like 37-39 is the best pressure for the Toyo RA1. Onve I was getting up to 40-42 I wad getting noticable temp peaks in the center of the tire., and it felt greasier. By backing off to 38, I had MUCH more confidence in the tire, and the temps were pretty even across.
    I run a Spec Miata
    Eric
    NER SM #12
    Aug 2002
    Austin, TX
    75
    Cool, thanks for the info guys. So it sounds like I was in the ballpark at least. I was seeing 39 or 38 by the time I got back to my paddock space.
    Marty, I'm not sure I understand your question. Yes, I normally run the s03 on my car in SCCA events. This event past was my first w/ NASA so I tried the Toyo since they are cool enough to offer some contingency money.
    FYI to hijack my own thread: the NASA weeekend rocked! Way more track time (more than 2x!) than I get w/ SCCA for the same entry fee + there was Toyo money to be had. I'm thinking it might be time to switch which club run the most...
    Jeff
    Dec 2001
    raleigh, nc, usa
    5,252
    I think he meant the "A" part of the ASO3. Isn't the "A" part for the autocross compound? "R" compounds are road race tires.
    Aug 2002
    Austin, TX
    75
    Opps, duh, my bad. Should be "R" for the road race compound.
    Jeff
    Mar 2004
    2
    Where do you all buy your Toyos now? I'd love to get another shaved set. Any suggestions as to where? Thanks.
    Aug 2002
    Austin, TX
    75
    Here is the list posted on the NASA website.
    http://veloce.nasaproracing.com/news/toyo_dealers.pdf
    Maybe call around a check prices, I got a couple of different quotes when I did.
    Jeff
    Jan 2002
    Des Moines, IA
    451
    I second Eric's recommendations of 38-39 lbs hot.
    Of course, I'm in a Miata too....so take it for what it's worth.
    Jarrod
    8,607
    I can heartily recommend http://www.philstireservice.com/ for Toyos. Tell him that "Kirk sent you" and he'll treat you right. I did a LOT of comparison shopping and he saved me $$.
    Mar 2004
    2
    Jeff and Kirk, thanks for the tips, but I actually found someone else. In the latest SportsCar there is an ad with Frisy Race Tires listed. They guy was super nice and the price for Toyo RA1 is $110 (+ $15 to shave).
    If you're looking for tire, give 'em a shot: www.frisbyracetire.com
    zracer22 Guest
    I just bought a set of Toyos from Frisby. Great price, $114 for 225/50-14. Only thing I'm not sure about, is the shaving. They are shaved, but not nearly as much as Vilven shaves off. They aren't quite full tread, but they would work as rains. You may want to specify tread depth for the shaving.
    Nov 2001
    Halifax, Nova Scotia
    639
    Lets elaborate on the toyo pressures. I find that on the 1-hour enduros that we do, 38-39 psi is too much for the latter of the race, thus the tires getting too greasy. I try to not let them get past 34-35 sometimes 36, starting out at 28 rear & 26 front.
    ITA CRX.
    I also flip the tires on the rims between race weekends to get max. even wear (in the dry of course).
    [This message has been edited by racer-025 (edited April 14, 2004).]
  15. #15
    San Jose, CA
    307
    Racer025,
    Thanks for the feedback there, that's exactly what I'm seeing, beginning of the race for the first 30 minutes or so, it's nice. THe last 5, it's greasy and slick.. It might be me overdriving the car, but I'll play with pressures too.
    PaulC
