what are your thoughts on using hearder wrap. pros and cons. It does not seem as popular as it was a few years ago
trd, We have to use it on our 2.3l Pinto or it gets way to hot under the hood! Dont want to melt tjhe battery. I feel it gives us a little hp plus make it safe woring under the hood and the rubber/ plastic lasts longer> Lobster
Another solution, better, though more expensive, is Swain Tech's White Lightning coating. It's a thick coating that is a true thermal barrier. The Jet Hot and similar coatings are just ceramic paint and only marginally effective.
George Roffe
Houston, TX
http://www.nissport.com
Scott is correct--WRAP = RUSTOUT
Speaking from experience, spring for a coating on those headers.
The wrap may be useful on starters or other components that do not build heat internally.
Good luck.
