Results 1 to 4 of 4
Thread: Model Line on ITCS Question
    Dec 2001
    raleigh, nc, usa
    5,252
    Default Model Line on ITCS Question
    Here's one for the rules nerds. I have a car that is listed on the ITCS line, with one weight for the coupe version and one for the convertible.
    I've just learned that the coupe's metal bumper assembly is much lighter (about 40 lbs each end, which is a lot) than the reinforced bumpers on the convertible. I've seen a set of coupe bumpers on a car here in Raleigh, and it appears the manufacturer simply welded in metal reinforcing to same bumper assembly on the convertible.
    So, it seems to me I could, at a minimum, find some coupe bumpers somewhere and bolt them on, correct? Same car, same ITCS line, different, lighter part on a different model?
    BUT, what I want to do, as I am having trouble locating someone who will just sell me bumpers and not an entire rotted, rusted, 25 yeard old British coupe, is take the bumpers I have and have the reinforcing bars cut out. Is "making" my bumpers into an allowable part allowed? I'm not sure, as I seem to be in a gray area. I'm certainly making a modification to increase performance, if I do this. However, the modification is to make an existing part "into" a part that I could simply bolt on if I could find it.
    Thoughts?
    Thanks guys.
    Jeff
    1980 Triumph TR8
    The Shape of Things that Break
    Wauwatosa, WI, USA
    2,658
    Jeff, read ITCS 17.1.4.C. second sentence.
    Is the coupe a TR8 ?
    Have Fun
    Apr 2002
    Houston, TX USA
    2,555
    Well, I'm not sure what David is trying to allude to, but......
    Technically you cannot do that. Pragmatically? Well, I assume the parts have different numbers on them. If the parts have the part numbers on them, then absolutely not. Otherwise, while I would not tell you that you can, as a practical matter, if you could make them be exactly the same as a coupe bumper and nobody could tell.... Well, then nobody could tell and I think you would skate. Again, technically it's illegal, so I leave you to your own conscience.
    If David is implying you are creating a model, I say pphhfftttt....... You are correct IMHO in saying both models are on the same line of the ITCS so you can interchange any parts. You just have to meet the weight requirement for your model.
    That's my opinion FWIW. IANATI (I am not a tech inspector).
    George Roffe
    Houston, TX
    http://www.nissport.com
    Jan 2002
    Somewhere in Upstate New York
    1,033
    The bumpers are the least of your problems. You've got more issues with the "25 year old British coupe" thing.
    If there is only one line in the ITCS for this car, then this is a question that you shouldn't be asking. Just do it. If you ask, it's just an opportunity for someone to say "no".
    Besides, there are not a lot of TR8 experts wandering around the IT paddock.
    Investment tip from a recovering British car guy: Go long in speedy-dry.
