Results 1 to 5 of 5
Thread: prelude suspension
    Sep 2003
    Lima, Ohio
    61
    Default prelude suspension
    I have been looking everywhere for suspension for my prelude which falls in 83-87 parts category and the only shock/strut I can find is the KYB Gr2 any suggestions on the best way to get a good suspension for this carit doesnt seem to be interchangeable with any other honda or acura
    Nov 2001
    Kensington, CT, USA
    1,013
    http://www.cyberauto.com/HondaPrelude.txt
    Here's a fairly good list of what's available for your car. There's not much. Dave has an '87 Prelude and has Leda Shocks and Coilovers. That's another way to go.
    Sep 2003
    Lima, Ohio
    61
    thanks for the link .. there isnt much for my car is there.. oh yeah thats because its such a good performer I dont need to make it better lol...
    any thoughts on exhaust manifold there is none listed there unless its the fuel infected engine and I have not been able to locate anything elsewhere either
    Sep 2003
    Lima, Ohio
    61
    I have actually located some Koni shocks and struts, now about spring rates and what not I would like to see about 1-1.5 inch drop what is a safe spring rate to run ??
    Oct 2002
    newington, ct
    4,182
    For a leda suspension, contact Karl at racers edge. I have been very happy with what they built me. www.racersedge-inc.com
    I know another IT racer that uses it in her car. The customer service is absolutely awesome!!! I was sooo impressed.
    The struts are non-adjustable. Several people recommended that I go this route when just beginning. Less stuff I need to modify / play with. Just adjust my driving and spring rates. As for spring rates, I use 400 lbs front and 600 lbs rear.
    Many people say to use much higher spring rates. Leda really seemed to know what they were talking about. They suggested for a novice to run these rates. They are a little more forgiving. I honestly don't think I would gain much if anything by using higher rates.
    I tried a aftermarket rear bar, but it was extremely tail happy. Yeah, spun a few times. I put the stock bar back in an purchased some poly. bushings. I am really happy with it now!
