Results 1 to 10 of 10
Thread: Coil Overs?
    Nov 2002
    Winterville, GA USA
    190
    Default Coil Overs?
    Hello,
    I was wondering how coilovers work, do they fit over your stock struts, or do they take place of them, what is the point of them, if you lower your car, will there be problems with your stock struts, will they blow as if you put on racing springs on stock struts? Thanks and please help!
    Simon
    www.simontibbett.evaluand.com
    GOING TO PICK UP MY MOTOR MONDAY!
    89 CIVIC FUTURE SCCA ITC CAR
    Apr 2002
    Houston, TX USA
    2,555
    Simon,
    IT legal coilovers use a sleeve that fits over your shock or strut. The sleeve is threaded and the lower spring perch is adjustable. You can get these from a few sources, including Koni and Ground Control.
    This also allows you to (actually requires you to) use race springs. Race springs come in many lengths and rates.
    You should not use coilovers with stock dampers (shocks and struts). At bare minimum you should get something like KYB AGX. They aren't the greatest, but they will handle the coilovers OK. We're still using them on our race car, but that will be changing soon.
    George Roffe
    Houston, TX
    http://www.nissport.com
    Jun 2002
    Bushkill PA
    813
    How soon?
    Crazy Joe
    #7 ITS pilot
    Nov 2002
    Winterville, GA USA
    190
    Hey,
    Ok, thanks for the info!
    Simon
    Apr 2002
    Houston, TX USA
    2,555
    Originally posted by dominojd:
    How soon?
    Tubing was delivered in Friday. I'm thinking we can have them inside a month now. Some of it's going to depend upon how busy our welder is.
    George Roffe
    Houston, TX
    Jun 2002
    Bushkill PA
    813
    keep me posted. that should hopefully fit in with the resurection of the beast.
    Crazy Joe
    #7 ITS pilot
    Apr 2003
    dallas, pa, usa
    166
    hey joe
    when are you going to be back?
    john costello
    #81 its rx7
    Jun 2002
    Bushkill PA
    813
    Hopefully by the runoffs.
    Crazy Joe
    #7 ITS pilot
    Apr 2003
    dallas, pa, usa
    166
    joe
    awesome. if you need help with anything drop me an email.
    john costello
    #81 its rx7
    [email protected]
    Jun 2002
    Bushkill PA
    813
    OKEE DOKEE
    Crazy Joe
    #7 ITS pilot
