Installing new wheel studs on new rotors???
I've installed new front rotors on my 1st Gen RX7 including new studs. I cleaned the threads on bith the studs and the hubs with a little brake cleaner, then I used red lock tite and cranked them in about 1 turn past snug. I torqued the lug nuts at 70 lbs. After only 5 miles I lost two studs from the drivers side hub and the other two were quite loose (passenger side studs seem fine). The hubs are Brembo and I don't believe the problem is because of poor quality OEM steel. Should I be using something like epoxy or JB Weld to??? I have a track day coming-up and am worried about losing a wheel. Thanks in advance for any advice.
