I tried to search but came up with nothing here and using Google. I have an '83 service manual that shows the bolt tightening pattern for the 18 engine bolts. My engines only have 17. Can someone point me in the right direction.
I sent you the 12A factory engine manual PDF file to your email off your website for a 1985 so I hope this helps. It also states the 12A does not have tension bolt number 11 so skip that one when tightening the tension bolts.
I need another email address from you to send this pdf file if possible?
Check your email.:024:
Tom I should have just gave you the link but here it is for others to use. I wasn't thinking could have skipped the email problems.
http://foxed.ca/foxed/index.php?page=rx7manual#firstgen
