Is anyone using aluminum wheel valves? If so where did you purchase them? I would like to replace the rubber wheel valves that came on my wheels. Any leads?
You can buy metal valve stems at most tire stores that sell alloy wheels like NTB. Summit, Jegs and NAPA should also have them available.
'89 CRX Si-SCCA ITA #99
'99 Prelude=a sweet song
[This message has been edited by jc836 (edited January 02, 2004).]
Thanks for the info. I am already aware of that and bought some from the Tire Rack. My complaint is that they aren't exactly light. I would prefer to get some aluminum ones. I'm sure someone knows where to get some aluminum wheel valves without having to order from Europe.Quote:
A little word of warning, the hard valve stems are a lot easier to break during a little wheel to wheel, the stock rubber is a little more forgiving. Just a thought ...
Only if the wheel valve sticks out that far. My wheel valves are next to the rim spokes, which are @ 2" from the wheel lip.Quote:
David, where are you located?
Our national at Pocono used to be right after NASCAR, and we paddock right where the goodyear guys did, and there were about 50 or more gasketed, metal valve stem covers laying all over the ground. I don't use them, but my friend who drives a club ford had a bunch of us picking them up for him. So, go to a nascar track after the race, and look around.
Meg
PS - my bad, I did not read the whole beginning (that you were talking about the whole stem)
[This message has been edited by megmeyer (edited January 04, 2004).]
I agree a 100%. I use rubber valves also...they give before they break .............a stock passenger rubber valve stem is good up to 65psi......there are two kinds, US and imports...you can usually tell by the valve core....Quote:
Phil Phillips
94 Acura Integra GSR #4
ITS/H3/ST1
www.philstireservice.com
Amsoil Dealer
distributor for FireCharger AFFF fire systems
Hoosier Tire Dealer
Toyo Tire Dealer
http://www.myerstiresupply.com/PDF/myers_s...0Accesories.PDF
The link is to a .pdf catalog section from Myer's Tire Supply.
On page two of the file (catalog pg 15), there's the LIGHT WEIGHT ALLOY VALVE that fits the standard 0.453" rim hole. Order #22-001, MFG # H-523MS.
Yeah, and if ya gotta lose that last bit of weight, ditch the cap & replace it with the AIRCRAFT VALVE CAP on .pdf page 6 (catalog pg 19.
john a
As already stated.
Use the shortest rubber valve stems you can use. Bob Vilven told me this 25 years ago and he repeated it last season.
Jack
