Originally Posted by
zracer22
I finally have all the bugs worked out of my 95 jetta that I race in GTS Challenge. The car is an ex world challenge car that swapped a 1.8T into. The transaxle has a Bildon race LSD witha FDR of 4.27. I put 225 HP and 250 TQ to the wheels. This past weekend, I had a problem with the turbo to manifold bolts coming loose, so i was down on power, but still turning 1:40 at MidOhio. I ran Toyo RA1 225-45-15. -1 camber rear and -4 camber front. I found that hot psi (43) was 15 psi higher than cold (28) after 20 minute session. If I went out with lower cold psi, the car wouldn't turn. Rear pressures were 32 cold and 38-39 hot. Car weighs 2600 lbs.
What tire pressures, toe and camber settings would you go with. I plan to use the toyos at least one more event, but my next tire ppurchase will be Hoosiers. So i'll take advice on both brands.
Thanks to all in advanced.
