Sure, there are V8 shocks available but it requires slight grinding on the spindles for them to fit. The early V8 cars face this same issue. If you have an early V8 you must shave the spindle in order to install the shocks that are made now ~or~ install the newer V8 spindles which is what everyone does outside of the SCCA to include circle track racers. Bottom line is if you want competitive performance shocks for the Mustang you will need to remove a small amount of material to install them. If Ron had not said anything No One would have known any better.
I agree. I think the rules need to clarify.
I was talking about the rear shocks and not the front struts.
