Motor Mount Question
I found over the weekend my front mount was broken...the style I have been using is the one piece that has the horizontal bolt. Now, I have come to find out that these are no longer made, very difficult to come by, and VERY expensive when compared to the other style (the one with a seperate bracket and has a stud on the mount itself). The question is how much am I losing by switching to this other style of mount? I have heard that the previous was stronger than the latter, so if someone could clarify, that would be great.
Alan
Note: either mount is legal in an A2 ITB Golf, I already found that out.
If poly mounts are legal, SPA sells a polyurethane insert to replace the rubber.
No, I do not believe the poly mounts are legal.
Does anyone else have any thoughts, suggestions, comments??? I am suprised at the speechlessness http://Forums.ImprovedTouring.com/it/smile.gif
Alan
I don't know if one is inherently better than the other but, from rallying experience, I can tell you that stiffer and/or stronger is not always better. Besides, the early style broke once already, right?
Kirk
(edit - I guess that my point is that putting one stronger mount into a package that was designed for a different one might chase the problem to one of the others.)
[This message has been edited by Knestis (edited July 02, 2002).]
I updated my MOTOR MOUNTS last year, from BSI, they have a HD Diesel package i bought from em, and have NO trouble at all.
GOOD LUCK
