I can vouch for this one - I took the entire fuel pump assembly off of a street car and mounted it to my race car at the track the night before my first win.:eclipsee_steering:
I have the luxury of using an enclosed trailer. Because of that I am able to bring almost and entire spare car this season.
on average here is what I store in my trailer.
2-4 spare axles (my old car used to eat them up 4 times a weekend!)
Spare IT spec engine
2 Transmissions
2 clutches
1 complete engine harness
2 ecu's
2 of every sensor
2 distributors
2 control arms
4 "softer" rain spec springs
2 knucles with wheel bearings and hubs installed
2 complete gasket sets
a LARGE assortment of nuts and bolts
Throttle cable and clutch cable
2 front rotors, brake lines and pads
2 rear rotors, lines and pads
2 front and 2 rear calipers
1 master cylinder
1 alternator
4 wheels and tires
4 rains
16 wheel studs and lug nuts
LOTS OF RACERS TAPE!!! :023:
As far as tools. My trailer has it's own dedicated tool set. Including a tire pyrometer, VAG COM laptop diagnostics tool, Wideband 02 and any other tool needed to fix my car.
I used to rather put my car on the trailer and go home but quickly learned that each weekend is on average a $1000 investment whether I finish or not, so why not give it my all and get it on the track.
^^ I beleive that spares list sums it up.. Personally I don't have the finicial backing nor the room to hold all those spares.. but that pretty much covered everything.
This is more like it, and exactly what I do. Travel light.
The track is the wrong place to do major work. If you are not ready when you get there, or need major work once there, its probably better/safer/cheaper to live to race another day and go home. <Knock on wood>, but in 17 years, the worst I had is the o2 sensor break out of the header, needing a piece of pop can and a couple hose clamps. Rest of the time I kinda fidget wondering if I should be wrenching on cars like everybody else.
I put a spare key to the race car in the binder that holds the log book. The binder goes in the duffle bag with the race suit. As said before, if you have it with you, you will never need it!!
I also tape a spare key for the tow vehicle in the glove box of the race car. I think I used it once, when the key was in a jacket on the other side of the paddock.
Assuming the Murphy-type Law "whatever tool you
forget, that is the tool you will need"...
and its Corollary "whatever tool you bring, you won't"...
whenever I pack the truck, I always make sure I take
with me the Biggest Baddest Prybar in the world.....:D
I make a master list in the setup book, noting parts #s and quantity, For rentals; I bring the clutch disc and tools, brake pads X 2 each, axles, make sure they are the right size ,100/90etc.
Rubber stuff, belts, hoses, cam seals, VC gasket,
radiator if you can fit it. , STOPLEAK .
Distribrutor, ignition wires, coil,plugs,module , I add one module mounted in the car, I can just unplug and plug in the other. I have not had any fail at the track in 15yrs of Dubs. Wire and connectors.
Head gasket, but every time it hurt the gaskset, the head was hurt. I just tape one to the roof of the van .
Front spindles and bearing ass. tie rod ass and the tools to change them . Caliper kits, Oil filter, mobil one,etc antifreeze and water. Clutch cable
Timing light
Oil cap, fuel cap, radiator cap!! sounds stupid dont it!!
hammer, big enough to keep the car knowing who is going to win.
MM
I like to bring the porta power dent puller, slide hammer and bondo - that way I know there will be no contact :-)
Best forgetfulness story - a GT1 friend came to NJMP last summer and realized he forgot his passenger side door. That dude felt pretty foolish.
Most important - get a list of inspection duties and tape it to your race car and make sure you check off ALL of the safety stuff before you load the car. I'm not the best mechanic (I've moved up from suck) but having this inspection checklist has really kept me out of a few jams BEFORE I got to the track.
Running in PDX's the guys who were constantly working on their car between sessions were usually the guys that cause your rungroup to be cut short due to a hose clamp that wasn't tightened thereby covering the course with fluids etc etc. Things get missed in an all out thrash, and I don't want to be that guy. I'll take what I can for minor repairs, and cuss alot when I find out I forgot a certain whatzit. Personally, if I tear it up so bad that I need to replace control arms, or front sections, I'm going home.
