Darin,
Not to get into an arguement, but I don't see what needs to be 'interpreted', it's pretty clearly spelled out that you can adjust the weight w/o any rule changes.
Apparently, not everyone agrees that it is so cut and dried...
Anyway, be that as it may, I'm also curious about some of the other reclassifications. Is it safe to assume that if they don't mention a weight change, that the cars are getting moved w/o any weight adjustments?
I would never "assume" anything around here, but to answer your question, yes, there are some cars recommended for reclassification that were recommended as such without a weight adjustment.
