Panasports are a good option for ITC and hold up fairly well. Last ones I weighed were 10.5 to 11 pounds on a postal scale in a 13 x 6.
If looking used, check some used OEM alloys- If you are running SCCA, you can use 13 or 14 or 15 inch diameter wheels but nothing wider than 6". This opens up a variety of OEM alloys (used) but the larger outer diameter of a 14 or 15" tire may have a negative impact on gearing, depending on where you run.
Hey Ryan, I would go to TireRack.com to look at wheels that will fit your car. If you click the more info link, it will have the offset, width, and weight. Also, you can see how they look on your car. Personally, I like the shiny aluminum ones you ran at drivers school, the red sripe was a nice touch.;)
Steven
