One person (honda-tech RR/AX) told me that the *ideal* ride height is between 22 1/4 to 22 5/8 to the fender lip in the front and 22 3/4 rear. That leaves me with about 2 inches of shock travel, which I think may be too low. I have been running around 2-2.5 degrees negative in the front and about 1.5 negative in the rear with 1/16 teo out in the front and zero rear. I'm just now really getting a real suspension under it and have lots to learn, so thanks for whatever advice you can give me.
I was also running with a progressive rate street kit and some big bump stops that had me set up way too soft, I'm just now putting the car back togeather and don't really know whats going to happen.
BTW,
koni rear
bilstein front
ground controls
Progress rear bar
SPC camber adjusters front and rear.
Most of the "brain" at HT left and started a new site about a year ago:
