ITS
1998 Acura Integra GSR
spec=2690
actual=2390
driver=175
ITS
spec=2690
actual=2390
driver=175
My old ITC Rabbit:
Spec Weight: 2000
Actual Weight: 1850
Driver Weight: 135
I had to race with a full tank of gas to finish with enough gas to make it so I was above weight.
Sam Rolfe
TBR Motorsports
#85 ITC VW Rabbit being converted to LPHP
#85 GP Scirocco
Hey Darin. I would like to submit the idea of bringing the weight down of cars that are too heavy for their class. For example, I was looking at the 86-89 Celica GTS and they are over 2600 lbs. at 135hp. If we look at the current top runners in ITA, all have a power to weight in the neighborhood of 19-17. If we could shave 100-150lbs off a lot of cars, then we would open up the class so its not a Honda vs. Nissan thing. Is that being looked at? I use the Celica as an example because they are common, have some aftermarket support, and are very durable. What do you think?
Ryan
1992 Acura Integra ITA
min weight 2480#
weight with driver: 2523
35# ballast
3 gal of gas in tank
driver 165#
be warned one track scale varies from another track scale...i have found up to 30# difference with the exact same amount of gas.
and the same scale at daytona read different 2 times in a row!!
1971 Datsun 510 - ITC
Spec: 2170
Actual: 2225 (w/ about 1 gal gas, 0 ballast)
Driver 200
1971 Datsun 510
ITC
2170 spec
2150 - with driver/gear, about 1 gal of gas and my tow bar installed instead of the FR bumper. No ballast
Driver 140
