Ron,
Here's a hypothetical question....
If you list the '99-'00 Z3's with mine, do I get to install the double VANOS system :D
Or how about the different rear sheet metal from the '00?
BTW, those two years ( '99-'00) came with 193 hp, where mine came with 189 hp. I think these changes coincide with the introduction of the e-46 328 vs. the e-36 328, but the Z3 was the last of the e-36 varients.
Also, you should also consider classing the '01-'02 Z3 3.0l at 225hp.
James
A lot of that will be worked out on the VTS sheets. I imagine that we'll try to keep it simple, so with minor changes cars would be on the same line.
