1st Gen GSL-SE Dyno Readings
I've seen a few posts about HP for the 7, but nothing for a ITS setup on the SE.
Yes I know the SE is down and out compared to the 2nd Gen. But that's what I have....
Last year I was only able to get (at the RW) 140hp @ 6800rpm, with 95% hp from 6000 to 7800rpm.
This is with factory ignition system, dual 2" pipes (over rear axle) merging into 3" in/out Dynomax super turbo muffler. Still factory airbox w/ K& N filter. I haven't installed a fuel pressure reg yet...Will this help out? I'm looking to add a MSD box to try to help out the factory ignition system.
Are there any other SE's out there that are ITS and are willing to share HP readings? And w/o going into alot of detail, any suggestions to try to wring out a few more hp?
