Originally posted by racerdrew43:
Mr GRJones-
You raise a good point about cam timing. I don't have a Kent motor,and maybe this is a stupid question, but, is there a procedure for checking the cam timing? I always line the crank mark to TDC at full advance (with the timing light)and there is a mark on the cam sprocket to line up at a dot in the head, but, how accurate is that, and what if the block was decked for the extra 1/2 point of compression? This may be fundemental but, you have to learn some how.
THANKS
Drew
Drew,
