For a bit, I use a high speed steel/milling bit. Very hard but you need to go slow or you dull it out in minutes.
Dumbell plates from Sports Authority work wonders. They are cast out of cheap material and easy to drill. Make sure you use a good new bit for this project though and keep it going slow and well oiled.
I would not go the shot route.
I purchased my exercise weights from a second hand sporting goods store. I bought the cheapest plates (four 25# plates) with no brand name on them and drilling through them was relatively easy. We stepped up through four drill bit sizes using a cordless drill and it took no time at all. A couple bolts to hold the plates to the floor and all was good. It seems exercise weights are very much a case of "you get what you pay for." In the case of using exercise weights as race car ballast, it seems you probably want to go cheap.
10 dollars a 25# plate works for me. cheaper if you shop around. But I was in a bind and having little luck on the used market around here.
Tried lead shot, on the kitchen stove in mom's cast iron skillet... Bad idea!
Later molded a small charcoal furnace out of plaster, used an air nozzle to get the coal plenty hot and melted the lead in small iron crucible. This worked pretty well.
Now we just buy plumber's lead in 25lbs increments, drill and bolt.
