What are you seeing for top speeds at the end of the back straight?
Thanks.
Thanks.
125-129 depending on conditions.
Thanks Zsolt.
Probably a little higher in an rx7 or youngs tr8. Not in my car but i have heard close to 140 in other rx7's
Come on Earl, every (non-racer) I speak to gets told that my SSM is hitting "about 148" at the end of the front straight...
Misread the title thought he was asking about cms
134 here and I don't think I'm the fastest. The RXs are slippery.
That is just an ugly unfounded rumor to get weight added to the RX7. :rolleyes:
I really could not tell you with the current car. I did not add the speed sensor to the Stack system with this install. I will pull some data and run it through the gear program and see what we were doing.
With gear program and RPM it gives me 135 2 places at CMS. I would not swear to that as it only takes a small change in RPM to be off. This was also in the draft with a green wedge opening up a hole the size of a tank. :D
hmm just got back from running at charlotte in the rain. my data showed 125.9 going to the stripe. but I know I was going faster in the night race. probably 128 range.
