AIM Evo 4 and Mychron3 dash and data acq system
For Sale
AIM EVO 4 data acquisition system like new with original packaging, instructions, cd-rom and all wiring.
Included in the system is an optional Mychron3 Dash display with gear indicator, shift lights and 4 programmable warning lights.
New ECU/OBD-II port data cable for Subaru/Saab 92X ecu.
Description:
EVO4 is the latest system from AiM. EVO4 is a compact, standalone logger that has GPS and a 3-axis accelerometer built in. While it is great as a portable unit that can be easily moved between vehicles, it also has all the features you would expect for a permanent installation, such as 5 analog channels, 2 speed inputs, CAN ECU and expansion capabilities, and the ability to add external displays.
EVO4 Features:
• Integrated GPS
• Integrated 3-axis accelerometer
• 5 analog input channels
• RPM input
• 2 wheelspeed inputs
• 8MB of non-volatile memory
• GPS Lap Timing (Capable of using infrared lap beacon, beacon and receiver not included)
• Sampling rates: digital inputs up to 50 Hz, analog thermocouple up to 100 hz, analog potentiometer up to 1000 Hz
• CAN/Serial (RS-232) interface to connect to ECUs
• Compatible with CAN expansion modules such as GPS, SmartyCam, LCU-1 Wideband, Channel/Thermocouple Expansion, and Memory Key
• Fast USB download to your PC and Race Studio 2 Analysis software
Dash description:
MyChron3 Dash for EVO4 Features:
• RPM Graphical Display with configurable scaling
• (1) Selectable display field for RPM, speed, best lap time or battery voltage
• (2) Selectable display fields for analog inputs; a button on the display switches to a second page with 2 different measures
• Last Lap Time
• 10 LED Shift Lights (green, yellow red)
• 4 LED Alarms, fully configurable for minimum or maximum alarms
System has been sold
