1st gen RX-7 large axle versus small axle diameter
I am in the process of procuring a pumkin, pig, 3rd member or whatever you care to call the differental assembly that carries the ring & pinion for a 1st gen RX-7. I live in a diferent state than the seller. The seller does not know if the deal is from a small or large axle rearend. He has no axles. Without an axle how does one determine if the assembly is for a small or large axle?
The large axle has 26 splines & is 1.060 diameter over the splines.
How many splines are on the small axle & what diameter over the splines is the small axle ?
Thanks http://Forums.ImprovedTouring.com/it/wink.gif
