Originally posted by bcarter:
OK, I agree that it is probably the MC. I went back to the car after 24 hours, and there was NO pedal at all. Must be air. There is no loss of fluid, we bench bled the master, bled the brakes before every race, and spent half of each race keeping the pedal up. Get's confusing, all that pumping, heel-toeing, braking etc. Actually went off once with my foot caught between pedals.
No parking brake.
I have the solution. I am replacing everything !
New MC from Mazda, not rebuilt. Getting the vacuum booster rebuilt. Trying to find a new proportional valve. Then with a pressure bleeder, at HIGH psi, I will go through the whole system, going back to my old (and functioning) calipers, one by one until I can get a pedal.
Try this. After the m/c bench bleed, bolt it on, then bleed it from each of the lines that are attached to it, then go around and do the calipers. Two quarts of dot 5 brake later, the car will stop on a dime through meer thought.(slight exaggeration).
