There are small advantages to be had by running a 15" wheel with lower profile tire over a 14", if your ratio you are lookinng for is available, but more often than not the biggest advantage of 15" wheels is the number of take-offs available. However I have done pretty good with finding new or good take-offs for cheap for 14" on this site.:shrug:
If the diamter rule goes into affect I would investigate the use of 13" wheels for the MR2. swapping wheels and tires is alot cheaper than a final drive, and can be swapped per the track. 15" wheel for Daytona, 14" for robeling, 13" for CMP. but talk aobut an additional expense. having to have at minimum 3 sets of tires on different wheels for one car for a dry setup, then there are spares...
I am against the width issue, too big of a can of worms, that help some and not others.. If a rule is written IMHO it should affect all (or as close as possible to it) and not for additional performance.
