Calling - 924Guy - Fuel Cell Installation?
Mr. V.S.
Did you install a fuel cell? If so, what pitfalls can you warn me about?
I'm getting ready to put one in a '83 944, and the more I think/plan/plot/ about it, the more involved it gets.
I've found a write up on other VW-GTI installations where they have had to add low pressure pump to pull fuel out the top, send to fuel filter, then aux/surge tank, then to original pump. Do you think the 944 stock fuel pump would need this kind of help? It currently pulls the fuel out the bottom of the tank, I don't know if it is capable of pulling the fuel up and out of the fuel cell.
Can you use the original 2" supply tube that comes down the rear pillar and still satisify the bulkhead seperating the fuel cell rule? Or...should I create/install a filler tube that goes thru the spare tire area out the back of the car?
I have plenty of questions...but I'll take a break right here.
JM http://Forums.ImprovedTouring.com/it/smile.gif
