To clear up a few misconeptions about the FES and CES endurance series. The CES, Citrus Endurance Series, was started by Bill Weston when he was the RE of the FL. Region. It combined any of the Endurance races held by the Central Fl. Region (CFR) and The FL. Region into a stand alone series with end of the year Champions etc. The actual races were run at the same time an ECR was run. in either of the Regions. The idea was that those who didn't wish to participate in all the ECR series races and tow to all of the many tracks in the SEDIV would have a mini-series to participate in. Thus it was possible to get points in both ECR(if registered) and the CES at the same time. It was also possible to get CES points for Endros run by the Regions that were not ECR'S. The CES,....joint CFR FL.Region venture.... was disbanded after two years and the FL.Region established the FL. Endurances Series...FES... This Series was to be run at ECR'S and Fl. Region Enduros at Moroso and Homestead conducted by the Fl. Region. The FES rules are the same as the ECR rules with one or two slight differences that are covered in the Supps. This series continues to run in 2007 in the FL. Region.
The Fl. Region event at Homestead,in June, will be a DOUBLE ECR as well as a Double FES....same Bat Time, same Bat Channel. Those of you who are running for ECR points might want to give this event some thought. The cancelled ECR at Daytona will be for whatever series points they plan to establish for their races. There has been no talk of reinstituting the joint CES Series at this time. Since this is a CFR event, no FES points are at stake or will be awarded. I hope this answers a few questions and clears up some mis- information.
Capt. John
