Sorry another dumb question.
I know I can not remove the interior door trim from the front doors but as I race a 4 door
Can I remove the door trim from the rear doors. It makes sence that I could as 2 door cars get to remove the trim from the rear seating area.
Anyone come accross same issue and what did you do.
Cheers SteveP
You can, but you must replace it with aluminum sheet, as spelled out in the GCR. Your front door trim may be swapped as well. Or you may gut the front doors completely IF you intrude into the space with a NASCAR door bar set up. As defined in the GCR it's rather minimal.
