For the sake of argument though, what about a car (like the audi diesels) that have roughly half the horse power that they do torque. Would you still tune to the peak HP curve if the torque had started to go away? I know from driving trucks that they have great pull at the lower part of the gear, then just fall off as the rev's increase since they don't make much in terms of power. Go to your next higher gear and get that grunt again.
I'd still map out the HP/torque curve and see where they overlap for each gear. The diesel may have a wildly different peak torque vs HP number - but since the torque happens so low in the rev range, the peaks will be close to each other. It is still the case that you want to be in the meaty HP point of the curve for acceleration.
My comment about the different ratios each having merit is in regard to where on track I'm shifting - ie not trying to upshift on the steep part of an uphill, or having to either upshift for a 100 yards or run higher RPM than I like.
Yep - I can understand that. I can run most tracks with a 4.6 rear end. However, at Summit Point, that 4.6 means I have to shift in the carosel (instead of right after), and that I also have to perform a downshift entering a turn that requires very little braking. So my braking is spread out a little more (to do the downshift) AND I can't just do a nice soft left-foot brake for the turn. So I'm going to try a 4.3 ratio.
