What can I expect?
I changed out the control arm and rear beam bushings with bearings, so what can I expect for handling now that I don't have the flex of the bushings? What other changes have you had to make when you changed to bearings?
(And yes Mike, I read your book but decided to go this way.)
More push.
The DRS is quite a bit faster.
My next area for more speed;Lots more rear air pressure,less spring, some toe out(zero scrub) along with the DRS. I am trying to get the easiest rolling race car.
So far it has worked with the HP car.
