That's all gone now. Double pipes/mufflers replaced with singles and the cats have been deleted. The exhaust changes lost me about 35 pounds. I also chucked the manifolds for long tubes.
BillF: Be careful if you swap to long tube headers. I bought off-the-shelf headers from Pacesetter and they hung about 2.4 inches off the ground. I had a race shop modify them to get them up another inch. A better bet is to have customs made for your car as there is alot of room under the floorpan for maximum clearance.
Ron: My cage weighs a bit more than most. I have very tight fitments to maximize safety. In fact, with the doors closed you might be hard pressed to see the cage in the car unless you got real close. McMahan Autosports near Akron, OH built my cage. They're recoginized as one of the finest cage builders in this region. They build cages for several Koni and World Challenge teams.
