I recently purchased an ex-SSC ’95 Neon with a friend it we need to replace a front hub. From what I’ve been hearing, this is a weak spot of the Neon but is fairly easy to replace. I was told that instead of just buying a hub, bearings then having it pressed in, it is easier and less expensive to purchase a hub assembly. I did some searching on various sites (primarily related to Mopar parts) but wasn’t able to find anything like that. Any recommendations on this? Also, are there any companies that you suggest compared to others?
In one of the other Neon threads, someone suggested using ACR hubs. Probably a dumb question, but will that fit a SOCH Neon?
I suppose the other thing I need to figure out is if it has the 13" or 14" brakes as asked on several of the parts sites. LOL
