Miata Transmission Bearing Fit
'91 daily driver. When I disassembled it, the front main bearing was very tight in the bell housing. Likewise when assembling - I had to use the long case screws to pull it together. With it assembled, it is so tight I can't turn the input shaft without turning the ouput shaft. I didn't check yet, but the front bearing probably doesn't protrude enough to get the snap ring on. I haven't taken measurements yet, but it seems like the bearing is too large or the hole is too small.
How do I fix this?
- Bearing is somehow oversize? Replace it?
- Heat the bell housing before trying to assemble it?
- Take a dremmel to the bell housing? (yikes)
