coilover sleeves
I am attempting to put coilover sleeves on a '85 golf. I have to use stock replacement struts as per my rules. The problem I have is that the sleeve won't fit over the struts end cap that holds the rod and piston in. I've measured the sleeve and the strut's body, and it would fit perfectly, but I can't get it over the end cap. I notice that the end cap is threaded onto the strut body. I am worried about removing the cap as I would imagine it holds pressurized oil. I would like to hear your ideas.
Scott
Nope, no pressurized oil. If they are threaded caps then it is just a strut insert, so you can just pop it out. Some were not inserts though (newer models I think) and they do not have screw on caps. Just latch onto the very top edge of them and twist hard!
Steve
did you already cut the spring perch off?
88 ITB Scirocco
It shouldn't be pressurized, but it will probably have some oil in it (heat transfer fluid).
MARRS #25 ITB Rabbit GTI
