Have you tried one of the hi torque starters? I'm just throwing stuff out there. The other thing that occured to me, when I asked how to wire up the kill switch, you said run the positive cable to the switch then back to the starter. You said (I think) to use 2 gauge wire. That sounded thin to me, I understand thicker wire meant more weight, so I figured if it worked, should be thick enough. Maybe when hot is not enough. Could test theory by temporarily removing long cables to switch with short stock type cable.
The hi torque starter would be illegal, but it might work.
