I will be putting in a rule request change on this and was wondering how you guys felt.
• Spec Miata cars completely* conforming to Spec Miata class specifications are eligible for STL.
*With the exception of:
May remove restrictor plate.
Tires may conform to 9.1.4.P.1.
Wheels may conform to 9.1.4.3.F.1.
1.6L SM may run at 2132 lbs.
1.8L SM may run at 2398.5 lbs.
I know it may sound like a lot but it's not much really and even with those allownences a SM car is way under developed then an STL car.
The reason for the request would be to help make the class be more appealing for the tons of SM cars that may double dip. It would help make the SM care more competitve with true STL cars. Most guys won't run a different tire, but some may, and that would make for closer racing. Most will run the same SM wheel, but some may, go with a lighter 15x7. Who know some may just turn there car into a full STL car.
It's also quick and easy, pulling the plate, ballast, and slapping on new wheels would take no time.
Anyways let me know what you think. This is my first time doing this so need advice on how to do this and the best wording.
Thanks!
